Salta al contenuto principale
Ematic EGQ307 Speaker Replacement
Cosa ti serve
  1. Ematic EGQ307 Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Ematic EGQ307 Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
  2. Ematic EGQ307 Speaker Replacement: passo 2, immagine 1 di 2 Ematic EGQ307 Speaker Replacement: passo 2, immagine 2 di 2
    • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
    • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
  3. Ematic EGQ307 Speaker Replacement: passo 3, immagine 1 di 2 Ematic EGQ307 Speaker Replacement: passo 3, immagine 2 di 2
    • Once you pry off the plastic backing, you will expose the battery and the motherboard. Then remove the tape on the speaker wire.
  4. Ematic EGQ307 Speaker Replacement: passo 4, immagine 1 di 3 Ematic EGQ307 Speaker Replacement: passo 4, immagine 2 di 3 Ematic EGQ307 Speaker Replacement: passo 4, immagine 3 di 3
    • Carefully remove tapes holding speaker in place.
    • Disconnect the speaker wires from the motherboard.
    • When working with device, make sure the battery is dead and there is not plugged in to the charger to limit the risk of shock.
  5. Ematic EGQ307 Speaker Replacement: passo 5, immagine 1 di 2 Ematic EGQ307 Speaker Replacement: passo 5, immagine 2 di 2
    • Pry the speaker out of the plastic casing to replace it with the new speaker using the spudger.
    • If replacing the speaker, you will need a soldering kit to reconnect the wires with the new speaker after disconnecting the old speaker.
    • How To Solder and Desolder Connections.
Conclusione
To reassemble your device, follow these instructions in reverse order, note you will need to solder for this replacement.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 286
