Salta al contenuto principale
Edwin the Duck Speaker Replacement
Cosa ti serve
  1. Edwin the Duck Speaker Replacement, Speaker: passo 1, immagine 1 di 2 Edwin the Duck Speaker Replacement, Speaker: passo 1, immagine 2 di 2
    • Unscrew the four 9mm screws with a T8 bit
    • Remove the back plate off
  2. Edwin the Duck Speaker Replacement: passo 2, immagine 1 di 2 Edwin the Duck Speaker Replacement: passo 2, immagine 2 di 2
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin resulting in not having a waterproof cover.
  3. Edwin the Duck Speaker Replacement: passo 3, immagine 1 di 1
    • Using the J1 bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Speaker Replacement: passo 4, immagine 1 di 2 Edwin the Duck Speaker Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. So open it very slowly.
  5. Edwin the Duck Speaker Replacement: passo 5, immagine 1 di 2 Edwin the Duck Speaker Replacement: passo 5, immagine 2 di 2
    • Using the plastic opening tool, pull up the black tab up until it stops.
    • Be careful not to pull the black tab too far up, otherwise the cable won't be able to secure anymore.
    • Pull up the white cable tab up slowly
  6. Edwin the Duck Speaker Replacement: passo 6, immagine 1 di 2 Edwin the Duck Speaker Replacement: passo 6, immagine 2 di 2
    • Use the J1 bit to unscrew all four screws attached to the motherboard.
    • Use the J1 bit to unscrew both 9 mm screw attached to the white plastic plate.
  7. Edwin the Duck Speaker Replacement: passo 7, immagine 1 di 1
    • Lift up the motherboard and speaker, and place to the side like done so in the image.
  8. Edwin the Duck Speaker Replacement: passo 8, immagine 1 di 2 Edwin the Duck Speaker Replacement: passo 8, immagine 2 di 2
    • Take the speaker and by using the soldering iron, unsolder by the red and white wires.
    • For more detailed information on how to solder and desolder connections, please see this guide.
    • Replace the new speaker and solder the two wires back into place. The red wire goes on the left and white wire goes on the right.
Conclusione
UW Tacoma, Team S1-G4, Rose Fall 2017 Membro di UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 284
