Salta al contenuto principale
Eclipse 180G2 MP3 Video Player speaker Replacement
Cosa ti serve
  1. Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: passo 1, immagine 1 di 2 Eclipse 180G2 MP3 Video Player speaker Replacement, Outer Case: passo 1, immagine 2 di 2
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: passo 2, immagine 1 di 3 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: passo 2, immagine 2 di 3 Eclipse 180G2 MP3 Video Player speaker Replacement, Remove inner circuit from case shell: passo 2, immagine 3 di 3
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
  3. Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: passo 3, immagine 1 di 2 Eclipse 180G2 MP3 Video Player speaker Replacement, Internal Speaker: passo 3, immagine 2 di 2
    • Identify the speaker. Pull the speaker away from the device so that wires are exposed.
    • Using a wire cutter, sever the red and black cables that are connecting the speaker to the circuit board.
    • You will need to solder the new speaker wires to connect it to the device.
Conclusione
  • To reassemble your device after completion of replacement, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Jesse Minor
Membro da: 01/15/15
668 Reputazione
3 Guide realizzate
USF Tampa, Team 1-4, Tanski Winter 2015 Membro di USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,068
