Salta al contenuto principale
EasySMX ESM-9100 Joystick Replacement
Cosa ti serve
  1. EasySMX ESM-9100 Joystick Replacement, Bottom Case: passo 1, immagine 1 di 1
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
  2. EasySMX ESM-9100 Joystick Replacement: passo 2, immagine 1 di 3 EasySMX ESM-9100 Joystick Replacement: passo 2, immagine 2 di 3 EasySMX ESM-9100 Joystick Replacement: passo 2, immagine 3 di 3
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
  3. EasySMX ESM-9100 Joystick Replacement, Joystick: passo 3, immagine 1 di 2 EasySMX ESM-9100 Joystick Replacement, Joystick: passo 3, immagine 2 di 2
    • Firmly pull off the two analog sticks (joysticks) from the potentiometers.
    • Be careful when removing the analog sticks as excessive force can cause damage to the potentiometer.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Altre 5 persone hanno completato questa guida.
Alex Vala
Membro da: 03/19/24
837 Reputazione
6 Guide realizzate
1Commento della guida
جديد
ربط واير
ايهم ذولفقار - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 100
Tutti i Tempi: 1,070
