Salta al contenuto principale
EasySMX ESM-9100 Face Buttons Replacement
Cosa ti serve
  1. EasySMX ESM-9100 Face Buttons Replacement, Bottom Case: passo 1, immagine 1 di 1
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
  2. EasySMX ESM-9100 Face Buttons Replacement: passo 2, immagine 1 di 3 EasySMX ESM-9100 Face Buttons Replacement: passo 2, immagine 2 di 3 EasySMX ESM-9100 Face Buttons Replacement: passo 2, immagine 3 di 3
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
  3. EasySMX ESM-9100 Face Buttons Replacement, A/B/X/Y Buttons: passo 3, immagine 1 di 2 EasySMX ESM-9100 Face Buttons Replacement, A/B/X/Y Buttons: passo 3, immagine 2 di 2
    • Gently pull out the buttons by the rubber backing from the top cover.
    • Be gentle so the buttons don't fall off the rubber back as you pull it out.
  4. EasySMX ESM-9100 Face Buttons Replacement: passo 4, immagine 1 di 2 EasySMX ESM-9100 Face Buttons Replacement: passo 4, immagine 2 di 2
    • Gently pull each face button off of the rubber backing.
    • The buttons should be on the rubber in order of Y at the top, B to the right, A at the bottom, and X to the left.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Alex Vala
Membro da: 03/19/24
746 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 25
Tutti i Tempi: 75
