Salta al contenuto principale
EVGA x17 Optical Sensor Board Replacement
Cosa ti serve
  1. EVGA x17 Optical Sensor Board Replacement, Optical Sensor Board: passo 1, immagine 1 di 1
    • Remove the mouse skates to reveal 5 screws.
  2. EVGA x17 Optical Sensor Board Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the 5 screws that secure the bottom panel.
  3. EVGA x17 Optical Sensor Board Replacement: passo 3, immagine 1 di 1
    • Remove the weight chamber cover.
  4. EVGA x17 Optical Sensor Board Replacement: passo 4, immagine 1 di 1
    • Slowly slide a spudger into and around the bottom of the panel, prying until a "popping" sound is heard.
    • You can also use an iFixit opening tool to pry open the bottom panel.
  5. EVGA x17 Optical Sensor Board Replacement: passo 5, immagine 1 di 2 EVGA x17 Optical Sensor Board Replacement: passo 5, immagine 2 di 2
    • Remove the 2 screws to gain access to the sensor board.
  6. EVGA x17 Optical Sensor Board Replacement: passo 6, immagine 1 di 1
    • Pop the optical sensor out and replace it.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 254
