Introduzione
Follow this guide to replace the belts on an EDCO PRO KL-18 Concrete Saw model 39600-HD.
Cosa ti serve
Chock the wheels to prevent the machine from moving while you are working on it.
Flip the ignition switches on the motor and the handle bar into their "OFF" positions.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 9/16 inch socket to remove the two bolts securing the belt guard to the main frame.
Use a 9/16 inch wrench to loosen the lock nut on the belt-tensioner bolt.
Use a 9/16 inch socket to remove the belt-tensioner bolt from the frame.
Use a 9/16 inch wrench to remove the nut securing the ground wire to the engine block.
Use a 9/16 inch wrench to loosen the four nuts securing the engine block to the frame, two on the front and two on the back.
Lift the outermost belt out of its pulley groove and rotate the motor pulley to remove it.
Repeat for the two remaining belts.
Place the guide bar onto the ground out of the way of the blade guard.
Lift the guide bar back up off the ground into its vertical position.
