Introduzione
Follow this guide to replace the power cord on a EDCO Disk Grinder model 50200-HD.
Cosa ti serve
Ensure the machine is unplugged.
Turn the power switch counterclockwise into the OFF position.
Use a Phillips screwdriver to remove the screw securing the red on/off lever.
Use a Phillips screwdriver to remove the four screws securing the upper half of the switch housing to the lower half.
Use a 3/8Â inch socket to remove the bolt securing the power cord loom clamp to the switch bracket.
Use two adjustable wrenches to unscrew the strain relief fitting by turning the locknut counterclockwise relative to the strain relief fitting.
1-1/16Â inch lock nut
15/16Â inch strain relief fitting
