Salta al contenuto principale
Dyson V8 Animal Brush Bar Replacement
Cosa ti serve
  1. Dyson V8 Animal Brush Bar  Replacement, Brush Bar: passo 1, immagine 1 di 1
    • Push the red button and then slide the brush head off of the shaft.
    • The shaft must be held from moving when sliding the brush head off.
  2. Dyson V8 Animal Brush Bar  Replacement: passo 2, immagine 1 di 3 Dyson V8 Animal Brush Bar  Replacement: passo 2, immagine 2 di 3 Dyson V8 Animal Brush Bar  Replacement: passo 2, immagine 3 di 3
    • Insert a coin into the slot on the side of the brush head.
    • Turn the coin counter clock wise to unlock the brushbar.
    • Pull the brushbar straight out of the brush head.
    • Clean all debris off of the brushbar and from inside the brush head.
    • The brushbar will spring outwards slightly when unlocked successfully.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S19-G1, White Winter 2020 Membro di Cal Poly, Team S19-G1, White Winter 2020
CPSU-WHITE-W20S19G1
4 Membri
10 Guide realizzate
4 Commenti
Did that but brush still will not spin.
walt.florence - Replica
I can't remove the brush, it springs outwards but keep firmly attached to the "axis". I've also tried to remove the transparent cover, by removing all the screws I've found on it (6 in total) but seems impossible. Can anyone please post a step by step guide about how to dissemble the whole brush bar??
Henar Lanchas López - Replica
I’m saving my Pennys for the “coin tool”. It does seem hauntingly familiar however….
Enrico Crocetti - Replica
I am unable to insert a coin into the slot provided. No problem previously
Mgt trotter - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 139
Tutti i Tempi: 4,953
