Salta al contenuto principale
Dyson Pure Cool AM11 Oscillation Motor Replacement
Cosa ti serve
  1. Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: passo 1, immagine 1 di 3 Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: passo 1, immagine 2 di 3 Dyson Pure Cool AM11 Oscillation Motor Replacement, Base: passo 1, immagine 3 di 3
    • With the device flipped upside down, use a Phillips #1 screwdriver to remove the 4 screws holding the 3 tabs down.
  2. Dyson Pure Cool AM11 Oscillation Motor Replacement: passo 2, immagine 1 di 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: passo 2, immagine 2 di 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: passo 2, immagine 3 di 3
    • Remove all 3 tabs that you unscrewed.
  3. Dyson Pure Cool AM11 Oscillation Motor Replacement: passo 3, immagine 1 di 2 Dyson Pure Cool AM11 Oscillation Motor Replacement: passo 3, immagine 2 di 2
    • Using a Torx T20 Screwdriver, remove the screw in the center of the base.
    • Remove the two screws connected to the rotation arm.
    There are instructions missing here. The black middle panel once removed gives access to two screws that are connected to the rotation arm (visible in the photo above), these need to be removed.
    Alex Howarth - Replica
  4. Dyson Pure Cool AM11 Oscillation Motor Replacement: passo 4, immagine 1 di 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: passo 4, immagine 2 di 3 Dyson Pure Cool AM11 Oscillation Motor Replacement: passo 4, immagine 3 di 3
    • Lift the base of the housing from the rest of the fan.
    • Be careful not to pull too hard while lifting the lower body housing as there is wires that run throughout the housing that could be damaged if too much force is used.
  5. Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: passo 5, immagine 1 di 2 Dyson Pure Cool AM11 Oscillation Motor Replacement, Oscillation Motor: passo 5, immagine 2 di 2
    • Using a T20 Torx screwdriver, remove the two screws on either side of the motor.
  6. Dyson Pure Cool AM11 Oscillation Motor Replacement: passo 6, immagine 1 di 2 Dyson Pure Cool AM11 Oscillation Motor Replacement: passo 6, immagine 2 di 2
    • (Optionally) Use a jimmy around the edge of the motor to loosen it from its housing.
    • Lift the motor out of its housing.
    • Ensure that you do not grab the motor by the swing arm as you may damage both the motor and surrounding components.
Linea Traguardo
2Commenti sulla guida
Where’d you get the motor
Jon Murch - Replica
any luck finding the proper motor replacement?
Kay -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 35
Tutti i Tempi: 745
