Salta al contenuto principale
Dynex DX-WEGRTR Motherboard Replacement
Cosa ti serve
  1. Dynex DX-WEGRTR Motherboard Replacement, Unscrew top cover.: passo 1, immagine 1 di 1
    • Remove the two Phillips #00 screws in the bottom of the device securing the casing.
    • Two 7.8 mm Phillips screws
    • Both of the screws are covered by the blue sticker, so they won't be visible instantly. Try feeling the plastic with your screwdriver until you find the hollow openings.
  2. Dynex DX-WEGRTR Motherboard Replacement, Prying the top cover off.: passo 2, immagine 1 di 1
    • Gently pry the edge of the vessel with a plastic opening tool, the previously used screwdriver, or your hands. Move your tool around all the edges of the router until you get all four of the plastic holders.
    • When prying off the front edge of the router, be careful to not insert your tool too deep into the device, for you may damage the LED connectors.
  3. Dynex DX-WEGRTR Motherboard Replacement, Unscrew the motherboard out of place.: passo 3, immagine 1 di 1
    • Use your handy Phillips screwdriver to unscrew the Phillips #00 screw to the lower left side of the motherboard.
    • One 4.4 mm Phillips #00 screw.
  4. Dynex DX-WEGRTR Motherboard Replacement, Slide antennas out.: passo 4, immagine 1 di 2 Dynex DX-WEGRTR Motherboard Replacement, Slide antennas out.: passo 4, immagine 2 di 2
    • Carefully slide the plastic housing of the antennas (the back cover of the router) up and out of its slot.
    • You may need to move the motherboard at this time in order to giggle the antenna's housing off.
    • Be sure to remove the cable connecting the motherboard and the antenna from its holding compartment at the right edge of the router (See image two). Pulling on either the motherboard or the antenna's housing while the cable is still secured may damage either or both components.
  5. Dynex DX-WEGRTR Motherboard Replacement, Take the motherboard out of its place.: passo 5, immagine 1 di 1
    • Finally, remove the motherboard from its place making sure to not pull the cable connecting the antennas.
Conclusione
Angel Leon
Membro da: 10/10/14
101 Reputazione
1 Guida realizzata
USF Tampa, Team 1-19, Donnelly Fall 2014 Membro di USF Tampa, Team 1-19, Donnelly Fall 2014
USFT-DONNELLY-F14S1G19
1 Membro
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 372
