Salta al contenuto principale
DualShock 3 Battery Replacement
Cosa ti serve
  1. DualShock 3 Battery Replacement, Step 1: passo 1, immagine 1 di 3 DualShock 3 Battery Replacement, Step 1: passo 1, immagine 2 di 3 DualShock 3 Battery Replacement, Step 1: passo 1, immagine 3 di 3
    • This is the Dualshock 3 controller
    • On the back of the controller, there will be five 7.2mm Phillips screws securing the body of the controller. (The five screws are circled in black.)
    • Remove each of the five screws from the back of the DualShock controller.
  2. DualShock 3 Battery Replacement, Step 2: passo 2, immagine 1 di 1
    • Push the center of the rear cover (between the two analog sticks) and carefully lift the lower edge away from the rest of the controller.
  3. DualShock 3 Battery Replacement, Step 3: passo 3, immagine 1 di 1
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, but be careful so that you won't pop off the #2 triggers.
    • Here is a DualShock trigger guide on the IFIXIT website in case you need to reattach the #2 triggers.
  4. DualShock 3 Battery Replacement, Step 4: passo 4, immagine 1 di 1
    • Move the battery off the motherboard so you have enough clearance to access the battery connector.
  5. DualShock 3 Battery Replacement, Step 5: passo 5, immagine 1 di 2 DualShock 3 Battery Replacement, Step 5: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Carefully pull the battery connector away from the socket that is attached to the motherboard. ( Battery connector is circled in black.)
    • It may be safer to use a tool like tweezers or pliers to pull the battery connector out of the socket.
    • Now you can dispose of the old battery safely. For example taking old used batteries to a household hazardous waste facility.
Conclusione
Altre 2 persone hanno completato questa guida.
Marcus Aiken
Membro da: 11/08/16
178 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 198
Tutti i Tempi: 2,482
