Salta al contenuto principale
DualSense Edge L1 and R1 Buttons Replacement
Cosa ti serve
  1. DualSense Edge L1 and R1 Buttons Replacement, Remove the L1 and R1 buttons: passo 1, immagine 1 di 3 DualSense Edge L1 and R1 Buttons Replacement, Remove the L1 and R1 buttons: passo 1, immagine 2 di 3 DualSense Edge L1 and R1 Buttons Replacement, Remove the L1 and R1 buttons: passo 1, immagine 3 di 3
    • The L1 and R1 buttons are held in by two clips. If only one clip releases, move your spudger to the other side of the button to release the remaining clip. Don't continue prying on one side after a clip is released, or you risk breaking the other clip.
    • Insert the flat end of a spudger in the gap between the L1 and L2 buttons.
    • The buttons tend to shoot out in the next step. You can place your thumb over the button to prevent this.
    • Use the spudger to pry out and remove the L1 button.
    • Repeat this process to remove the R1 button.
Conclusione
Spencer Pennington
Membro da: 09/09/23
23.311 Reputazione
125 Guide realizzate
Guide Team Membro di Guide Team
Staff
10 Membri
15.897 Guide realizzate
1Commento della guida
Where can I buy a quality replacement for the r1 button, I bought some but they don't fit properly
Fly - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 201
Tutti i Tempi: 2,339
