Salta al contenuto principale
Dual-sided Vanity Mirror Cover Replacement
Cosa ti serve
  1. Dual-sided Vanity Mirror Cover Replacement, mirror cover: passo 1, immagine 1 di 1
    • Measure the length of the mirror for purchasing a new replacement part.
    Where at to buy a BE82MB conair mirror
    dendo1317 - Replica
  2. Dual-sided Vanity Mirror Cover Replacement: passo 2, immagine 1 di 2 Dual-sided Vanity Mirror Cover Replacement: passo 2, immagine 2 di 2
    • Using the Phillips head screwdriver, unscrew the screw on the side of the mirror.
    • The screws are very small and can be easily lost. Be aware while loosening them.
  3. Dual-sided Vanity Mirror Cover Replacement: passo 3, immagine 1 di 2 Dual-sided Vanity Mirror Cover Replacement: passo 3, immagine 2 di 2
    • Remove the other screw from the opposite side of the mirror.
  4. Dual-sided Vanity Mirror Cover Replacement: passo 4, immagine 1 di 3 Dual-sided Vanity Mirror Cover Replacement: passo 4, immagine 2 di 3 Dual-sided Vanity Mirror Cover Replacement: passo 4, immagine 3 di 3
    • Lift off the mirror piece by pulling up at the sides.
    • Tilt the mirror upward.
  5. Dual-sided Vanity Mirror Cover Replacement: passo 5, immagine 1 di 2 Dual-sided Vanity Mirror Cover Replacement: passo 5, immagine 2 di 2
    • Remove the bolt on the left side connecting the second mirror piece to the stand by twisting it counter-clockwise.
  6. Dual-sided Vanity Mirror Cover Replacement: passo 6, immagine 1 di 2 Dual-sided Vanity Mirror Cover Replacement: passo 6, immagine 2 di 2
    • Remove the larger bolt on the opposite side by twisting it counter-clockwise.
  7. Dual-sided Vanity Mirror Cover Replacement: passo 7, immagine 1 di 1
    • Take off the mirror piece
    Hello,
    I found these steps to be very helpful! I literally have the EXACT same beauty mirror and was wondering where you found the replacement mirror. As my mirror broke the same side as these instruction describe. Is there anyways you can provided a link as to where I can purchase the replacement??? PLEASEEE!!!!
    - Thank you
    Samantha Venegas - Replica
Conclusione
To reassemble your mirror with a new mirror piece, follow these instructions in reverse order.
3Commenti sulla guida
Where do you buy replacement magnification and regular mirror to reinstall?
Andrea Westberg - Replica
I broke my vanity magnifying 20times looking to replace , please advise where can I buy it or get it repaired.
I live in Defence Colony New Delhi
Thank you
Raj Gujral
Raj Gujral - Replica
I am having a hard time finding out where I can purchase a replacement mirror. 10x magnifying. I can't get a hold of the manufacturer. It is a Vesaur 2 sided lighted makeup mirror.
Roberta Golub - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,314
