Salta al contenuto principale
Dual-sided Vanity Mirror Cover Replacement
Cosa ti serve
  1. Dual-sided Vanity Mirror Cover Replacement, mirror cover: passo 1, immagine 1 di 1
    • Measure the length of the mirror for purchasing a new replacement part.
  2. Dual-sided Vanity Mirror Cover Replacement: passo 2, immagine 1 di 2 Dual-sided Vanity Mirror Cover Replacement: passo 2, immagine 2 di 2
    • Using the Phillips head screwdriver, unscrew the screw on the side of the mirror.
    • The screws are very small and can be easily lost. Be aware while loosening them.
  3. Dual-sided Vanity Mirror Cover Replacement: passo 3, immagine 1 di 2 Dual-sided Vanity Mirror Cover Replacement: passo 3, immagine 2 di 2
    • Remove the other screw from the opposite side of the mirror.
  4. Dual-sided Vanity Mirror Cover Replacement: passo 4, immagine 1 di 3 Dual-sided Vanity Mirror Cover Replacement: passo 4, immagine 2 di 3 Dual-sided Vanity Mirror Cover Replacement: passo 4, immagine 3 di 3
    • Lift off the mirror piece by pulling up at the sides.
    • Tilt the mirror upward.
  5. Dual-sided Vanity Mirror Cover Replacement: passo 5, immagine 1 di 2 Dual-sided Vanity Mirror Cover Replacement: passo 5, immagine 2 di 2
    • Remove the bolt on the left side connecting the second mirror piece to the stand by twisting it counter-clockwise.
  6. Dual-sided Vanity Mirror Cover Replacement: passo 6, immagine 1 di 2 Dual-sided Vanity Mirror Cover Replacement: passo 6, immagine 2 di 2
    • Remove the larger bolt on the opposite side by twisting it counter-clockwise.
  7. Dual-sided Vanity Mirror Cover Replacement: passo 7, immagine 1 di 1
    • Take off the mirror piece
Conclusione
To reassemble your mirror with a new mirror piece, follow these instructions in reverse order.
3 Commenti
Where do you buy replacement magnification and regular mirror to reinstall?
Andrea Westberg - Replica
I broke my vanity magnifying 20times looking to replace , please advise where can I buy it or get it repaired.
I live in Defence Colony New Delhi
Thank you
Raj Gujral
Raj Gujral - Replica
I am having a hard time finding out where I can purchase a replacement mirror. 10x magnifying. I can't get a hold of the manufacturer. It is a Vesaur 2 sided lighted makeup mirror.
Roberta Golub - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 3,313
