Salta al contenuto principale
Dragon Touch Y88X Plus Motherboard Replacement
Cosa ti serve
  1. Dragon Touch Y88X Plus Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove the back case using a plastic opening tool or spudger.
    • Start at the corners and work your way around the perimeter of the tablet.
    • Be gentle to avoid damaging the case or any internal components.
  2. Dragon Touch Y88X Plus Motherboard Replacement: passo 2, immagine 1 di 1
    • Remove any adhesive strips keeping wires in place.
  3. Dragon Touch Y88X Plus Motherboard Replacement: passo 3, immagine 1 di 1
    • Desolder the wires connected to the motherboard to disconnect the battery and speaker.
  4. Dragon Touch Y88X Plus Motherboard Replacement: passo 4, immagine 1 di 2 Dragon Touch Y88X Plus Motherboard Replacement: passo 4, immagine 2 di 2
    • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three ZIF connectors.
    • Be sure to pry up on the hinged flap, not the connector socket.
    • Use a spudger to slide the ribbon cables from the connectors.
  5. Dragon Touch Y88X Plus Motherboard Replacement: passo 5, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the three 4 mm screws from the edges of the motherboard.
  6. Dragon Touch Y88X Plus Motherboard Replacement: passo 6, immagine 1 di 1
    • Gently lift the motherboard from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
Cody Camara
Membro da: 11/01/23
149 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Membro di UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 67
