Salta al contenuto principale
Dragon Touch A1x Plus Cameras Replacement
Cosa ti serve
  1. Dragon Touch A1x Plus Cameras Replacement, Battery: passo 1, immagine 1 di 1
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Cameras Replacement: passo 2, immagine 1 di 2 Dragon Touch A1x Plus Cameras Replacement: passo 2, immagine 2 di 2
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Cameras Replacement: passo 3, immagine 1 di 1
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Cameras Replacement: passo 4, immagine 1 di 1
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Cameras Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Cameras Replacement: passo 6, immagine 1 di 2 Dragon Touch A1x Plus Cameras Replacement: passo 6, immagine 2 di 2
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
  7. Dragon Touch A1x Plus Cameras Replacement, Cameras: passo 7, immagine 1 di 2 Dragon Touch A1x Plus Cameras Replacement, Cameras: passo 7, immagine 2 di 2
    • Remove black tape holding the cameras to the motherboard.
  8. Dragon Touch A1x Plus Cameras Replacement: passo 8, immagine 1 di 2 Dragon Touch A1x Plus Cameras Replacement: passo 8, immagine 2 di 2
    • Use your fingernail to flip up the small locking flap on the ZIF connector.
    • Pull the ribbon cable from the ZIF connector.
  9. Dragon Touch A1x Plus Cameras Replacement: passo 9, immagine 1 di 1
    • Remove the front camera from the device using your fingers.
  10. Dragon Touch A1x Plus Cameras Replacement: passo 10, immagine 1 di 2 Dragon Touch A1x Plus Cameras Replacement: passo 10, immagine 2 di 2
    • Melt the glue holding the rear camera in place using a hair dryer.
    • Insert the metal spludger under the rear camera and pry it free from the device.
Conclusione
Josh Null
Membro da: 03/21/18
313 Reputazione
3 Guide realizzate
IUPUI, Team S5-G5, Baechle Spring 2018 Membro di IUPUI, Team S5-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G5
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 160
