Salta al contenuto principale
Dragon Touch A1x Plus Battery Replacement
Cosa ti serve
  1. Dragon Touch A1x Plus Battery  Replacement, Battery: passo 1, immagine 1 di 1
    • Insert the plastic opening tool between the white back cover and black front over.
  2. Dragon Touch A1x Plus Battery  Replacement: passo 2, immagine 1 di 2 Dragon Touch A1x Plus Battery  Replacement: passo 2, immagine 2 di 2
    • Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
    • You may need to pry the back cover off using the opening tool while moving it along the edge.
  3. Dragon Touch A1x Plus Battery  Replacement: passo 3, immagine 1 di 1
    • Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
  4. Dragon Touch A1x Plus Battery  Replacement: passo 4, immagine 1 di 1
    • Use the hair dryer to melt the glue holding the battery to the device.
    • Be careful not to overheat the battery as it could cause the battery to combust.
  5. Dragon Touch A1x Plus Battery  Replacement: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Insert the plastic card under the battery and use it to remove the battery from the device.
    • Be careful not to deform the battery.
  6. Dragon Touch A1x Plus Battery  Replacement: passo 6, immagine 1 di 2 Dragon Touch A1x Plus Battery  Replacement: passo 6, immagine 2 di 2
    • Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
Conclusione
Josh Null
Membro da: 03/21/18
313 Reputazione
3 Guide realizzate
IUPUI, Team S5-G5, Baechle Spring 2018 Membro di IUPUI, Team S5-G5, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G5
3 Membri
6 Guide realizzate
Un commento
where can you find a replacement battery for this tablet?
Lupe Rdrgz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,820
