Salta al contenuto principale
Dr. Martens Mary Janes Elastic Replacement
Cosa ti serve
  1. Dr. Martens Mary Janes Elastic Replacement, Elastic: passo 1, immagine 1 di 2 Dr. Martens Mary Janes Elastic Replacement, Elastic: passo 1, immagine 2 di 2
    • Remove the buckle from the strap with the broken elastic.
  2. Dr. Martens Mary Janes Elastic Replacement: passo 2, immagine 1 di 1
    • Using a pair of fabric scissors, trim down any frayed elastic on the shoe.
  3. Dr. Martens Mary Janes Elastic Replacement: passo 3, immagine 1 di 1
    • Cut the new elastic to a desired length.
    • Be sure the new elastic is the same dimensions as the existing elastic on the shoe.
  4. Dr. Martens Mary Janes Elastic Replacement: passo 4, immagine 1 di 1
    • Using a sewing pin, pin the new elastic onto the old elastic.
  5. Dr. Martens Mary Janes Elastic Replacement: passo 5, immagine 1 di 1
    • Insert the buckle through the new elastic.
  6. Dr. Martens Mary Janes Elastic Replacement: passo 6, immagine 1 di 3 Dr. Martens Mary Janes Elastic Replacement: passo 6, immagine 2 di 3 Dr. Martens Mary Janes Elastic Replacement: passo 6, immagine 3 di 3
    • Fold down the elastic over the buckle.
    • Cut a small hole with scissors where the prong of the buckle meets the elastic.
    • Put the prong through the hole.
  7. Dr. Martens Mary Janes Elastic Replacement: passo 7, immagine 1 di 1
    • Pull the elastic fully through buckle.
  8. Dr. Martens Mary Janes Elastic Replacement: passo 8, immagine 1 di 2 Dr. Martens Mary Janes Elastic Replacement: passo 8, immagine 2 di 2
    • Pin both sides of the elastic into place on the old elastic.
  9. Dr. Martens Mary Janes Elastic Replacement: passo 9, immagine 1 di 2 Dr. Martens Mary Janes Elastic Replacement: passo 9, immagine 2 di 2
    • Hand sew the elastic into place along the pin.
    • When sewing, be cautious when using a sewing needle.
  10. Dr. Martens Mary Janes Elastic Replacement: passo 10, immagine 1 di 2 Dr. Martens Mary Janes Elastic Replacement: passo 10, immagine 2 di 2
    • Trim down the excess elastic to your desired fit.
  11. Dr. Martens Mary Janes Elastic Replacement: passo 11, immagine 1 di 2 Dr. Martens Mary Janes Elastic Replacement: passo 11, immagine 2 di 2
    • Insert the buckle back into shoe strap.
Conclusione
To reassemble your shoe elastic, follow these instructions in reverse order.
Shu Yin Yu
Membro da: 02/01/24
193 Reputazione
1 Guida realizzata
UC Davis, Team 1-6, Andersen Winter 2024 Membro di UC Davis, Team 1-6, Andersen Winter 2024
UCD-ANDERSEN-W24S1G6
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 31
Tutti i Tempi: 108
