Introduzione
This guide demonstrates how to replace the joystick covers of the Diswoe Switch-01 controller. Wear and tear may cause the controller to behave as if it is receiving an input without any. This usually is caused by dirt and debris, or defects from manufacturing. Follow this guide if the joystick has stopped working and cleaning the contacts does not work.
Before you begin the repair, make sure the controller is off and disconnected from the console.
Cosa ti serve
Use a Phillips screwdriver to remove the two screws at the bottom of the hand grips.
Remove the handgrips from the controller.
Push on alternating sides of the battery connector to "walk" it out of its socket.
If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
Additionally, if the previous step didn’t work, use the arms of a pair of sharp tweezers to gently push the connector out of its socket by inserting them into the cutouts.
Remove the PCB that is connected near the triggers and the motors at the bottom of the controller.
Once everything is disconnected, the motherboard can be removed.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
