Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will allow users of the Samsung Galaxy S Blaze to understand how to take the phone apart. The guide will make future repairs easier to accomplish. The disassembly of the phone is an easy process with no surprises. You will need to be careful with the screws that are inside the device, the screws will strip easily. To properly disassemble the phone you will need a Phillips Head screw driver size 00 and a flat wedge opening device.
Parti
Nessuna parte specificata.
  1. Remove the back plate.
    • Remove the back plate.
  2. Remove the battery from the device.
    • Remove the battery from the device.
  3. Use a Phillips head screwdriver size 00. Remove the 4mm screws from the frame.
    • Use a Phillips head screwdriver size 00.
    • Remove the 4mm screws from the frame.
    • The eight screws are all the same size.
  4. Remove the frame from the phone by using the blue plastic opening tool.
    • Remove the frame from the phone by using the blue plastic opening tool.
    • Work around the phone with the tool until the frame is off.
    • You may need to use a bit of force to pry off the frame.
  5. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  6. The volume rocker is attached to the frame by two plastic prongs.
    • The volume rocker is attached to the frame by two plastic prongs.
    • Unhook the prongs from the frame and remove the volume rocker.
  7. The SD card slot is held in place by a small tab.
    • The SD card slot is held in place by a small tab.
    • Unhook the tab of the SD card slot from the frame of the phone.
  8. The power button is attached to the phone with two prongs.
    • The power button is attached to the phone with two prongs.
    • Unhook the prongs of the power button from the frame of the phone.
  9. 4 ribbon cable connectors hold the motherboard to the phone. The first 3 are all on one side. Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
    • 4 ribbon cable connectors hold the motherboard to the phone.
    • The first 3 are all on one side.
    • Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
  10. Flip the motherboard over to access the last ribbon cable connector.
    • Flip the motherboard over to access the last ribbon cable connector.
    • Unlatch the final ribbon cable connector from the phone.
    • Remove the motherboard from the phone.
  11. All of the parts are seen here.
    • All of the parts are seen here.
Conclusione
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
Altre 2 persone hanno completato questa guida.
Jake Best
Membro da: 05/03/2015
261 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 530
