Salta al contenuto principale
Nokia 3100b Microphone Replacement
Cosa ti serve
  1. Nokia 3100b Microphone Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure your phone is turned off.
  2. Nokia 3100b Microphone Replacement: passo 2, immagine 1 di 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Nokia 3100b Microphone Replacement, SIM Card: passo 3, immagine 1 di 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Nokia 3100b Microphone Replacement: passo 4, immagine 1 di 1
    • Retrieve your SIM card.
  5. Nokia 3100b Microphone Replacement, Microphone: passo 5, immagine 1 di 1
    • Press the black tabs to release the front cover from the phone.
  6. Nokia 3100b Microphone Replacement: passo 6, immagine 1 di 1
    • Remove the front cover from the phone.
    • Set the front cover as indicated, aside.
  7. Nokia 3100b Microphone Replacement: passo 7, immagine 1 di 2 Nokia 3100b Microphone Replacement: passo 7, immagine 2 di 2
    • Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
    • Remove the screen assembly from the phone base.
    • Set the screen assembly aside.
  8. Nokia 3100b Microphone Replacement: passo 8, immagine 1 di 3 Nokia 3100b Microphone Replacement: passo 8, immagine 2 di 3 Nokia 3100b Microphone Replacement: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Note the location of the microphone.
    • Use tweezers to remove the microphone from the phone's base.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Cal Poly, Team 29-64, Johann Spring 2010 Membro di Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,255
