Salta al contenuto principale
Disassembling HP Photosmart c3180 Ink Cartridge Track
Cosa ti serve
  1. Disassembling HP Photosmart c3180 Ink Cartridge Track, Top Panel: passo 1, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track, Top Panel: passo 1, immagine 2 di 2
    • Before disassembling your printer, be sure that the printer has been unplugged.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 2, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 2, immagine 2 di 2
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 3, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 3, immagine 2 di 2
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 4, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 4, immagine 2 di 2
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 5, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 5, immagine 2 di 2
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 6, immagine 1 di 1
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 7, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 7, immagine 2 di 2
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
  8. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 8, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 8, immagine 2 di 2
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 9, immagine 1 di 1
    • Carefully lift the top panel of the printer away from the printer body.
  10. Disassembling HP Photosmart c3180 Ink Cartridge Track, Ink Cartridge Track: passo 10, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track, Ink Cartridge Track: passo 10, immagine 2 di 2
    • Set aside the top panel of the printer.
    • Remove the two T10 12 mm Torx screws from the top front of the printer
  11. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 11, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 11, immagine 2 di 2
    • Rotate the Printer 90 degrees counter clockwise.
    • Remove the scanner cable from the main circuit board.
    • Grasp the bottom of the cable and pull straight up. Do not wiggle it from side to side or twist it as this can damage the connection.
  12. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 12, immagine 1 di 1
    • Using both hands, lift the scanner tray from the body of the printer.
  13. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 13, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 13, immagine 2 di 2
    • Remove the power button circuit board from the support frame by pinching the left side, and pulling forward and to the left simultaneously.
    • Push up on the tab holding the secondary control circuit board with the spudger and pull it forward to remove it.
    • Be careful not to pull too hard on the cable connecting the power button control circuit board and the secondary control circuit board to the main circuit board
  14. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 14, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 14, immagine 2 di 2
    • Lift the support frame off of the printer body with both hands.
  15. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 15, immagine 1 di 1
    • Remove the printer door and paper tray by putting them in the closed position and not laying flat then rotating them upwards lift the left side up.
  16. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 16, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 16, immagine 2 di 2
    • Remove both of the ink cartridges by grabbing the front of the ink cartridge and pulling down.
    • Make sure that the printer carriage is pushed all the way to the right.
  17. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 17, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 17, immagine 2 di 2
    • Remove the T10 6 mm Torx screw on the left side of the track assembly.
    • Remove the T10 12 mm Torx screw on the left side of the track assembly.
  18. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 18, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 18, immagine 2 di 2
    • Gently push the ink cartridge carriage to the left side of the printer.
  19. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 19, immagine 1 di 1
    • Remove the two T10 6 mm Torx screws.
  20. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 20, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 20, immagine 2 di 2
    • Remove the cable connecting the ink cartridge carriage to the main circuit board.
    • Pull straight up to free the cable from the main circuit board. Do not twist or wiggle the cable as doing so can damage it.
    • You may need to lift the carriage up with one hand in order to reach the cable with the free hand as shown.
  21. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 21, immagine 1 di 1
    • Carefully remove the connector holding the drive motor wires to the main circuit board.
  22. Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 22, immagine 1 di 2 Disassembling HP Photosmart c3180 Ink Cartridge Track: passo 22, immagine 2 di 2
    • Slide the ink cartridge carriage all the way to the right side of the printer.
    • Using both hands, carefully lift the ink cartridge track off of the main body of the printer.
Conclusione
Altre 11 persone hanno completato questa guida.
Jim
Membro da: 10/06/11
1.557 Reputazione
10 Guide realizzate
Cal Poly, Team 20-30, Maness Fall 2011 Membro di Cal Poly, Team 20-30, Maness Fall 2011
CPSU-MANESS-F11S20G30
4 Membri
25 Guide realizzate
2 Commenti
Thank You sooo much….Just what I needed
One of the 4 pins on this spring loaded plastic piece on the carriage farthest one to the right popped off and for some reason it raised up and was stopping the carriage from sliding left..So once I got the carriage off it dropped back down ,spring is fine so I snapped the pin back in…cool i thought it was broken…So I’ll clean it up put it back together and see what happens
Sure hope I can get those cables back in rite
I’ll let you know!!! >>—-@—->
Knyte Spyder - Replica
Wpw its working
Got rid of the flashing orange light,carriage is sliding left an right ,printed a test page…WOOOHOOO!!!
Thank you all again so much
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 41
Tutti i Tempi: 11,009
