Salta al contenuto principale
Dirt Devil Scorpion Quick Flip Power Cord Replacement
Cosa ti serve
  1. Dirt Devil Scorpion Quick Flip Power Cord Replacement, Power Cord: passo 1, immagine 1 di 1
    • While holding the device by the handle, press the button on the left-hand side of the vacuum handle in order to release the nozzle from the body.
  2. Dirt Devil Scorpion Quick Flip Power Cord Replacement: passo 2, immagine 1 di 2 Dirt Devil Scorpion Quick Flip Power Cord Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #1 Screwdriver, remove all six of the 4 mm screws holding the shell together.
  3. Dirt Devil Scorpion Quick Flip Power Cord Replacement: passo 3, immagine 1 di 1
    • Using utility scissors, cut the black and white cables approximately an inch and a half above where they connect to the faulty power cord.
  4. Dirt Devil Scorpion Quick Flip Power Cord Replacement: passo 4, immagine 1 di 1
    • Using a soldering iron, fuse the black and white cables from the new power cord to where the previous cord was cut away.
    • Using electrical tape, cover the exposed area.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 281
