Salta al contenuto principale
Dirt Devil Scorpion Quick Flip Motor Replacement
Cosa ti serve
  1. Dirt Devil Scorpion Quick Flip Motor Replacement, Motor: passo 1, immagine 1 di 1
    • Gently remove filter adapter from the vacuum body by pressing the gray plastic release button.
  2. Dirt Devil Scorpion Quick Flip Motor Replacement: passo 2, immagine 1 di 1
    • Place the vacuum body on its left side and remove all 4mm screws with a Phillips #1 screwdriver.
  3. Dirt Devil Scorpion Quick Flip Motor Replacement: passo 3, immagine 1 di 1
    • Carefully take apart the shell of the vacuum body.
    • Cut the two wires attached to the motor and remove the motor from the body.
  4. Dirt Devil Scorpion Quick Flip Motor Replacement: passo 4, immagine 1 di 1
    • Solder the wires from the replacement motor to the wires connecting it to the power cord.
    • Carefully place the replacement motor back into its correct position in the vacuum body.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 24
Tutti i Tempi: 538
