Salta al contenuto principale
Dirt Devil Scorpion Quick Flip Circuit Board Replacement
Cosa ti serve
  1. Dirt Devil Scorpion Quick Flip Circuit Board Replacement, Circuit Board: passo 1, immagine 1 di 1
    • Push the button on the left-hand side of the handle.
    • Remove the filter holder from the main body.
  2. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 2, immagine 1 di 2 Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 2, immagine 2 di 2
    • Remove the first two 4 mm screws using a Phillips #1 Screwdriver.
    • Remove the last four 4 mm screws using a Phillips #1 Screwdriver.
    • Carefully take the device a part.
  3. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 3, immagine 1 di 2 Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 3, immagine 2 di 2
    • Identify the circuit board located in the inside of the handle.
    • Remove the gray switch located on top of the circuit board.
    • Using utility scissors, cut the wires 1/2 inch away from the circuit board.
  4. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 4, immagine 1 di 2 Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 4, immagine 2 di 2
    • Solder the new circuit board to the existing wires.
    • Using electrical tape or heat shrink tubing, cover the soldered area.
    • Place the new circuit board into the correct spot inside the handle.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 126
