Salta al contenuto principale
Dirt Devil Gator Motor Replacement
Cosa ti serve
  1. Dirt Devil Gator Motor Replacement, Motor: passo 1, immagine 1 di 1
    • Press the button found at the top of the vacuum to separate the suction cup and the motor halves.
  2. Dirt Devil Gator Motor Replacement: passo 2, immagine 1 di 3 Dirt Devil Gator Motor Replacement: passo 2, immagine 2 di 3 Dirt Devil Gator Motor Replacement: passo 2, immagine 3 di 3
    • Pull apart the two halves to obtain the back half and set the front half aside
  3. Dirt Devil Gator Motor Replacement: passo 3, immagine 1 di 3 Dirt Devil Gator Motor Replacement: passo 3, immagine 2 di 3 Dirt Devil Gator Motor Replacement: passo 3, immagine 3 di 3
    • Unscrew each of the 13 mm screws with the micro screwdriver.
    • Once unscrewed, pull the case of the Dirt Devil Gator apart.
  4. Dirt Devil Gator Motor Replacement: passo 4, immagine 1 di 3 Dirt Devil Gator Motor Replacement: passo 4, immagine 2 di 3 Dirt Devil Gator Motor Replacement: passo 4, immagine 3 di 3
    • Pull out the grey switch and circuit board from its slot in the red case.
    • Remove all of the wires from the vacuum to where only the battery and wires are left.
    • Firmly pull out the battery and motor assembly. The circuit board and wires will remain attached.
  5. Dirt Devil Gator Motor Replacement: passo 5, immagine 1 di 1
    • Remove the motor from the Dirt Devil Gator exterior by pulling slightly on the white socket.
    • Replace it with a new motor by fitting the motor back into its socket.
    • Be cautious when handling the batteries and wires.
    • Keep the grey on-off switch in the "off" position to ensure a quick reassembly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 430
