Salta al contenuto principale
Digitech XC- 5206 Wired Connections Replacement
Cosa ti serve
  1. Digitech XC- 5206 Wired Connections Replacement, Wired Connections: passo 1, immagine 1 di 2 Digitech XC- 5206 Wired Connections Replacement, Wired Connections: passo 1, immagine 2 di 2
    • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off. You may need to use extra force.
  2. Digitech XC- 5206 Wired Connections Replacement: passo 2, immagine 1 di 3 Digitech XC- 5206 Wired Connections Replacement: passo 2, immagine 2 di 3 Digitech XC- 5206 Wired Connections Replacement: passo 2, immagine 3 di 3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Wired Connections Replacement: passo 3, immagine 1 di 3 Digitech XC- 5206 Wired Connections Replacement: passo 3, immagine 2 di 3 Digitech XC- 5206 Wired Connections Replacement: passo 3, immagine 3 di 3
    • Cut zip-ties wrapped around red and green wires using scissors or pliers.
  4. Digitech XC- 5206 Wired Connections Replacement: passo 4, immagine 1 di 3 Digitech XC- 5206 Wired Connections Replacement: passo 4, immagine 2 di 3 Digitech XC- 5206 Wired Connections Replacement: passo 4, immagine 3 di 3
    • Pull wires out of ports using blunt nose tweezers.
  5. Digitech XC- 5206 Wired Connections Replacement: passo 5, immagine 1 di 2 Digitech XC- 5206 Wired Connections Replacement: passo 5, immagine 2 di 2
    • Remove green (left) and red (right) wired connection to speaker bulb using soldering station.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 127
