Salta al contenuto principale
Digital2 Platinum Pad 9 Volume Buttons Replacement
Cosa ti serve
  1. Digital2 Platinum Pad 9 Volume Buttons Replacement, External Cover: passo 1, immagine 1 di 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 2, immagine 1 di 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 2, immagine 2 di 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 3, immagine 1 di 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 3, immagine 2 di 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Volume Buttons Replacement, Volume Buttons: passo 4, immagine 1 di 1
    • You can locate the volume buttons on one of the longer sides of the tablet.
  5. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 5, immagine 1 di 1
    • Lift up the ZIF connector that is attached to the volume buttons ribbon cable.
  6. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 6, immagine 1 di 1
    • Then remove the ribbon cable from the ZIF connector.
  7. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 7, immagine 1 di 1
    • Make sure to separate the volume button's cable from the cable connecting the motherboard to the screen
  8. Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 8, immagine 1 di 2 Digital2 Platinum Pad 9 Volume Buttons Replacement: passo 8, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Then use the precision tweezers to grab the volume buttons.
    • Pull until the buttons come out.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 99
