Salta al contenuto principale
Digital2 Platinum Pad 9 Battery Replacement
Cosa ti serve
  1. Digital2 Platinum Pad 9 Battery Replacement, External Cover: passo 1, immagine 1 di 1
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Battery Replacement: passo 2, immagine 1 di 2 Digital2 Platinum Pad 9 Battery Replacement: passo 2, immagine 2 di 2
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Battery Replacement: passo 3, immagine 1 di 2 Digital2 Platinum Pad 9 Battery Replacement: passo 3, immagine 2 di 2
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Battery Replacement, Battery: passo 4, immagine 1 di 1
    • The battery is the bigger square object in the center of the device held down by 3 pieces of yellow tape.
  5. Digital2 Platinum Pad 9 Battery Replacement: passo 5, immagine 1 di 1
    • Carefully remove the tape that is holding down the battery.
  6. Digital2 Platinum Pad 9 Battery Replacement: passo 6, immagine 1 di 2 Digital2 Platinum Pad 9 Battery Replacement: passo 6, immagine 2 di 2
    • Lift up the battery it will be glued to the device.
    • Be sure to gently work it to loosen and remove so that you do not damage your device.
  7. Digital2 Platinum Pad 9 Battery Replacement: passo 7, immagine 1 di 1
Conclusione
Un commento
Where can one buy the battery?
BedfordGlen Board - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 293
