Salta al contenuto principale
Digiland DL1168A Rear Case Replacement
Cosa ti serve
  1. Digiland DL1168A Rear Case Replacement, Rear Case: passo 1, immagine 1 di 1
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Rear Case Replacement: passo 2, immagine 1 di 2 Digiland DL1168A Rear Case Replacement: passo 2, immagine 2 di 2
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Rear Case Replacement: passo 3, immagine 1 di 2 Digiland DL1168A Rear Case Replacement: passo 3, immagine 2 di 2
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 128
