Salta al contenuto principale
Digiland DL1168A Battery Replacement
Cosa ti serve
  1. Digiland DL1168A Battery Replacement, Rear Case: passo 1, immagine 1 di 1
    • Using an opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  2. Digiland DL1168A Battery Replacement: passo 2, immagine 1 di 2 Digiland DL1168A Battery Replacement: passo 2, immagine 2 di 2
    • Carefully lift back panel away from the body of the device.
    • Be gentle when lifting the back panel. The speaker wires are still connected to both the front and back panel.
  3. Digiland DL1168A Battery Replacement: passo 3, immagine 1 di 2 Digiland DL1168A Battery Replacement: passo 3, immagine 2 di 2
    • Desolder the four wires connecting the rear case to the motherboard.
    • Disconnect the wires from the motherboard.
    • Remove the rear case from the device.
  4. Digiland DL1168A Battery Replacement, Battery: passo 4, immagine 1 di 3 Digiland DL1168A Battery Replacement, Battery: passo 4, immagine 2 di 3 Digiland DL1168A Battery Replacement, Battery: passo 4, immagine 3 di 3
    • Desolder the three positive, negative, and neutral red, black, and white wires from the motherboard that are connected to the battery.
    • The soldering tool is hot, and will burn. Follow this link for instructions on Come saldare e dissaldare componenti elettrici.
  5. Digiland DL1168A Battery Replacement: passo 5, immagine 1 di 2 Digiland DL1168A Battery Replacement: passo 5, immagine 2 di 2
    • Using an opening tool, separate the battery from the tablet.
    • Follow the edge of the battery to loosen the glue.
  6. Digiland DL1168A Battery Replacement: passo 6, immagine 1 di 3 Digiland DL1168A Battery Replacement: passo 6, immagine 2 di 3 Digiland DL1168A Battery Replacement: passo 6, immagine 3 di 3
    • Once the glue is loosened, pry the battery away from the screen.
    • Pulling on the battery may cause you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 35
Tutti i Tempi: 564
