Salta al contenuto principale
DigiTech RP70 Input/Output ¼” Ports Replacement
Cosa ti serve
  1. DigiTech RP70 Input/Output ¼” Ports  Replacement, Motherboard: passo 1, immagine 1 di 2 DigiTech RP70 Input/Output ¼” Ports  Replacement, Motherboard: passo 1, immagine 2 di 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70 Input/Output ¼” Ports  Replacement: passo 2, immagine 1 di 2 DigiTech RP70 Input/Output ¼” Ports  Replacement: passo 2, immagine 2 di 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70 Input/Output ¼” Ports  Replacement: passo 3, immagine 1 di 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70 Input/Output ¼” Ports  Replacement: passo 4, immagine 1 di 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70 Input/Output ¼” Ports  Replacement, Input/Output ¼” Ports: passo 5, immagine 1 di 2 DigiTech RP70 Input/Output ¼” Ports  Replacement, Input/Output ¼” Ports: passo 5, immagine 2 di 2
    • Desolder the back of the motherboard where the damaged input/output port is located.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 10
Tutti i Tempi: 311
