Salta al contenuto principale
DigiLand DL718M Screen Replacement
Cosa ti serve
  1. DigiLand DL718M Screen Replacement, Back Panel: passo 1, immagine 1 di 1
    • Remove back panel by wedging the iFixit opening tool on all four sides of the device.
  2. DigiLand DL718M Screen Replacement, Screen: passo 2, immagine 1 di 1
    • Remove two silver Phillips #0 screws along the bottom of the internal panel.
  3. DigiLand DL718M Screen Replacement: passo 3, immagine 1 di 1
    • Remove the ribbon in the bottom left corner of the motherboard by lifting the black tab and sliding the ribbon out from the slot underneath the black tab.
  4. DigiLand DL718M Screen Replacement: passo 4, immagine 1 di 1
    • Remove the small, circular microphone on the left side of the device by sliding it out of its slot using an opening tool.
  5. DigiLand DL718M Screen Replacement: passo 5, immagine 1 di 1
    • Remove the front-facing camera in the top left corner of the device by sliding it out of its slot using an opening tool.
  6. DigiLand DL718M Screen Replacement: passo 6, immagine 1 di 1
    • Remove the three black Phillips #0 screws along the left side of the motherboard.
  7. DigiLand DL718M Screen Replacement: passo 7, immagine 1 di 1
    • Detach the black tape and the wire from the right side of the screen.
  8. DigiLand DL718M Screen Replacement: passo 8, immagine 1 di 1
    • Remove the rear-facing camera by prying it off of the back side of the screen using the an opening tool.
  9. DigiLand DL718M Screen Replacement: passo 9, immagine 1 di 1
    • Lift the motherboard and remove it from the device using an opening tool.
    • If there is any tape on the device that prohibits you from doing so, remove the tape.
  10. DigiLand DL718M Screen Replacement: passo 10, immagine 1 di 1
    • Remove the ribbon above the battery by lifting the black tab and sliding the ribbon out from the slot underneath the black tab using an opening tool.
  11. DigiLand DL718M Screen Replacement: passo 11, immagine 1 di 1
    • Pry the battery off of the back of the screen by wedging the iFixit opening tool underneath.
  12. DigiLand DL718M Screen Replacement: passo 12, immagine 1 di 2 DigiLand DL718M Screen Replacement: passo 12, immagine 2 di 2
    • Lift the screen from the plastic casing.
Conclusione
1Commento della guida
What happen after? How remove the LCD screen? ……..INCOMPLETE
jrtu2001 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 425
