Introduzione
In this guide you will be able to:
- Safely remove and put back together your device
- Accurately replace the screen of your device
Cosa ti serve
With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
Begin by locating the four 3mm silver screws that are holding the screen down to the digitizer. Set screws to the side.
Altre 4 persone hanno completato questa guida.
3Commenti sulla guida
I find it's not necessary to remove the batttery, but there are scews holding down the main circuit board that he left out.
នៅណាមានបង
ខ្ញុំទិញមួយ
ផ្ញើតាមឡានបានអត់
ខ្ញិំនៅតាកែវ ស្រុកកោះអណ្ដែត
