Salta al contenuto principale
Dell u3014 monitor repair. Power on problem.
Cosa ti serve
  1. Dell u3014 monitor  repair. Power on problem., Removing bezel: passo 1, immagine 1 di 2 Dell u3014 monitor  repair. Power on problem., Removing bezel: passo 1, immagine 2 di 2
    • The u3014 monitor opens the same as most other recent Dell monitors.
    • First remove the stand.
    • Remove the bezel. This can be done by hand and a plastic knife. Approaching the screen from behind, peel the bezel with your fingers (photo).
    • The rest follows quite easily, but in the corners you might need to insert a blade or similar to pry open the clips.
    • When removing the bezel, be careful with the control panel (stuck in place with glue, covered with glued-on strip) and power-button (2 screws).
  2. Dell u3014 monitor  repair. Power on problem., Isolating the PCB: passo 2, immagine 1 di 2 Dell u3014 monitor  repair. Power on problem., Isolating the PCB: passo 2, immagine 2 di 2
    • Remove the connectors. Black cable to backlight (push clip and pull). Two multi-color cables to LCD (push in the sides and pull). Power and control ribbon (pull). USB hub power (push clip and pull). USB ribbon (lift flap and remove).
    • The frame with PCB is held in place just by metal tape.
    • The USB hub is completely loose.
  3. Dell u3014 monitor  repair. Power on problem., Fixing the problem: passo 3, immagine 1 di 1
    • Caution: The circuit board contains capacitors (they look like cylinders) that can shock you if they discharge. Be careful not to touch them as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • To solve power on problems, inspect the board. In my case there was a cold solder joint that actually showed a little spark when plugged in (photo Q816). Re-soldering fixed it. Your case might be harder to find and fix.
    • Many repair guides talk about replacing all capacitors rather aimlessly. In this monitor they used Nichico caps which are very reliable. So that is an unlikely fix.
    • Be extremely careful fixing these switching power supplies, even more so in Europe where one has 230V. Discharge capacitors etc.
    • If you liked this guide, contribute your own.
    • If things are unclear, leave a comment.
Conclusione
Altre 5 persone hanno completato questa guida.
Mark
Membro da: 09/05/18
465 Reputazione
3 Guide realizzate
2 Commenti
what was the problem with this monitor?
Jason - Replica
This one had a power-on problem. I can’t remember if the power led came on at all.
I have now edited the text.
Mark -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 28
Tutti i Tempi: 3,491
