Salta al contenuto principale
Dell XPS 15 9575 Interconnect Cable Replacement
Cosa ti serve
  1. Dell XPS 15 9575 Interconnect Cable Replacement, Bottom Cover: passo 1, immagine 1 di 3 Dell XPS 15 9575 Interconnect Cable Replacement, Bottom Cover: passo 1, immagine 2 di 3 Dell XPS 15 9575 Interconnect Cable Replacement, Bottom Cover: passo 1, immagine 3 di 3
    • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
    • Use your T5 Torx driver to remove all eight 3.2mm hex screws holding down the back panel.
    • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
  2. Dell XPS 15 9575 Interconnect Cable Replacement: passo 2, immagine 1 di 1
    • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
    • Remove the bottom cover from the device when all sides are free.
  3. Dell XPS 15 9575 Interconnect Cable Replacement, Interconnect Cable: passo 3, immagine 1 di 2 Dell XPS 15 9575 Interconnect Cable Replacement, Interconnect Cable: passo 3, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove all four silver 3.2mm screws fastening the interconnect cable.
  4. Dell XPS 15 9575 Interconnect Cable Replacement: passo 4, immagine 1 di 2 Dell XPS 15 9575 Interconnect Cable Replacement: passo 4, immagine 2 di 2
    • Carefully wedge the plastic opening pick between the fan and the interconnect cable.
    • If this position does not release the interconnect cable, slide the opening pick along the edge until it is completely free.
    • Remove the interconnect cable.
  5. Dell XPS 15 9575 Interconnect Cable Replacement: passo 5, immagine 1 di 2 Dell XPS 15 9575 Interconnect Cable Replacement: passo 5, immagine 2 di 2
    • Use the nylon tweezers to remove the interconnect pins from each of the circuit boards.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 583
