Salta al contenuto principale
Dell XPS 15 9570 Heat Sink Replacement
Cosa ti serve
  1. Dell XPS 15 9570 Heat Sink Replacement, Base Cover: passo 1, immagine 1 di 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Heat Sink Replacement: passo 2, immagine 1 di 3 Dell XPS 15 9570 Heat Sink Replacement: passo 2, immagine 2 di 3 Dell XPS 15 9570 Heat Sink Replacement: passo 2, immagine 3 di 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Heat Sink Replacement: passo 3, immagine 1 di 2 Dell XPS 15 9570 Heat Sink Replacement: passo 3, immagine 2 di 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Heat Sink Replacement: passo 4, immagine 1 di 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Heat Sink Replacement, Battery: passo 5, immagine 1 di 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Heat Sink Replacement: passo 6, immagine 1 di 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Heat Sink Replacement: passo 7, immagine 1 di 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: passo 8, immagine 1 di 2 Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: passo 8, immagine 2 di 2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Heat Sink Replacement: passo 9, immagine 1 di 1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 65
Tutti i Tempi: 2,324
