Salta al contenuto principale
Dell XPS 15 9510 RAM Replacement
Cosa ti serve
  1. Dell XPS 15 9510 RAM Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 RAM Replacement: passo 2, immagine 1 di 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 RAM Replacement: passo 3, immagine 1 di 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 RAM Replacement, RAM: passo 4, immagine 1 di 1
    • Using both hands, pull the clips that hold the RAM in place.
  5. Dell XPS 15 9510 RAM Replacement: passo 5, immagine 1 di 2 Dell XPS 15 9510 RAM Replacement: passo 5, immagine 2 di 2
    • Gently, with both hands, pull the RAM up at a 45ยบ angle and take out the RAM.
    • Repeat the same process with the other RAM.
Conclusione
IUPUI, Team 2-1, Harley Summer 2023 Membro di IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 42
Tutti i Tempi: 564
