Salta al contenuto principale
Dell XPS 15 9510 Fan Replacement
Cosa ti serve
  1. Dell XPS 15 9510 Fan Replacement, Lower Case: passo 1, immagine 1 di 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Fan Replacement: passo 2, immagine 1 di 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Fan Replacement: passo 3, immagine 1 di 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Fan Replacement, Fan: passo 4, immagine 1 di 2 Dell XPS 15 9510 Fan Replacement, Fan: passo 4, immagine 2 di 2
    • Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
  5. Dell XPS 15 9510 Fan Replacement: passo 5, immagine 1 di 2 Dell XPS 15 9510 Fan Replacement: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Gently unplug the motherboard fan connector using a pair of tweezers.
  6. Dell XPS 15 9510 Fan Replacement: passo 6, immagine 1 di 1
    • Unplug the motherboard connector on the other fan using a pair of tweezers.
  7. Dell XPS 15 9510 Fan Replacement: passo 7, immagine 1 di 2 Dell XPS 15 9510 Fan Replacement: passo 7, immagine 2 di 2
    • Gently slide and then lift the fans out of their positions.
  8. Dell XPS 15 9510 Fan Replacement: passo 8, immagine 1 di 3 Dell XPS 15 9510 Fan Replacement: passo 8, immagine 2 di 3 Dell XPS 15 9510 Fan Replacement: passo 8, immagine 3 di 3
    • Repeat the previous step and remove the other fan.
Conclusione
Altre 3 persone hanno completato questa guida.
IUPUI, Team 2-1, Harley Summer 2023 Membro di IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 38
Tutti i Tempi: 1,193
