Salta al contenuto principale
Dell XPS 14 Speaker Replacement
Cosa ti serve
  1. Dell XPS 14 Speaker Replacement, Back Panel: passo 1, immagine 1 di 1
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
  2. Dell XPS 14 Speaker Replacement: passo 2, immagine 1 di 3 Dell XPS 14 Speaker Replacement: passo 2, immagine 2 di 3 Dell XPS 14 Speaker Replacement: passo 2, immagine 3 di 3
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
  3. Dell XPS 14 Speaker Replacement: passo 3, immagine 1 di 2 Dell XPS 14 Speaker Replacement: passo 3, immagine 2 di 2
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
  4. Dell XPS 14 Speaker Replacement: passo 4, immagine 1 di 3 Dell XPS 14 Speaker Replacement: passo 4, immagine 2 di 3 Dell XPS 14 Speaker Replacement: passo 4, immagine 3 di 3
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
  5. Dell XPS 14 Speaker Replacement, Speaker: passo 5, immagine 1 di 2 Dell XPS 14 Speaker Replacement, Speaker: passo 5, immagine 2 di 2
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
  6. Dell XPS 14 Speaker Replacement: passo 6, immagine 1 di 2 Dell XPS 14 Speaker Replacement: passo 6, immagine 2 di 2
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 197
