Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
  1. Close the laptop, flip the laptop over, and pop off the back panel with a flathead screwdriver.  The panel will be hanging by the hinges once open.
    • Close the laptop, flip the laptop over, and pop off the back panel with a flathead screwdriver. The panel will be hanging by the hinges once open.
  2. Use a T5 Torx screwdriver to remove the screws along the edge of the bottom cover.
    • Use a T5 Torx screwdriver to remove the screws along the edge of the bottom cover.
    • Use a magnetic board if possible to keep track of screws
    • Open the center cover and use a Phillips #00 screwdriver to remove single screw.
  3. Carefully remove back cover
    • Carefully remove back cover
  4. Disconnect the battery to prevent electrical shock.
    • Disconnect the battery to prevent electrical shock.
  5. Essential Electronics Toolkit
    Small Toolkit. Big Possibilities.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  6. Disconnect amber-colored daughter cable.
    • Disconnect amber-colored daughter cable.
  7. Use a Phillips #00 screwdriver to loosen the screws that secure the heatsink.
    • Use a Phillips #00 screwdriver to loosen the screws that secure the heatsink.
    • Screws cannot be fully removed from heatsink.
  8. Remove the heatsink.
    • Remove the heatsink.
    • Heatsink is a device used for absorbing heat and necessary to remove to reach the fan.
  9. Use Phillips screwdriver to remove cooling fan screws.
    • Use Phillips screwdriver to remove cooling fan screws.
  10. Unplug fan cable.
    • Unplug fan cable.
  11. Fan can now be removed and a new one can be installed.
    • Fan can now be removed and a new one can be installed.
Conclusione
Altre 3 persone hanno completato questa guida.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 953
