Salta al contenuto principale
Dell Venue 11 Pro USB Port Replacement
Cosa ti serve
  1. Dell Venue 11 Pro USB Port Replacement, Battery: passo 1, immagine 1 di 3 Dell Venue 11 Pro USB Port Replacement, Battery: passo 1, immagine 2 di 3 Dell Venue 11 Pro USB Port Replacement, Battery: passo 1, immagine 3 di 3
    • Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
  2. Dell Venue 11 Pro USB Port Replacement: passo 2, immagine 1 di 3 Dell Venue 11 Pro USB Port Replacement: passo 2, immagine 2 di 3 Dell Venue 11 Pro USB Port Replacement: passo 2, immagine 3 di 3
    • Below the battery pack, there are two lock mechanisms. Push EACH lock to the LEFT until it makes a click noise. Lift the battery from the bottom up and remove.
  3. Dell Venue 11 Pro USB Port Replacement, Frame: passo 3, immagine 1 di 2 Dell Venue 11 Pro USB Port Replacement, Frame: passo 3, immagine 2 di 2
    • Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
    • These screws are extremely small. Place the screws aside in a container or on your magnetic mat to prevent accidental loss.
  4. Dell Venue 11 Pro USB Port Replacement: passo 4, immagine 1 di 3 Dell Venue 11 Pro USB Port Replacement: passo 4, immagine 2 di 3 Dell Venue 11 Pro USB Port Replacement: passo 4, immagine 3 di 3
    • Slide the cover on the two middle ribbon cables out to remove it. It should uncover the orange cable connectors.
  5. Dell Venue 11 Pro USB Port Replacement: passo 5, immagine 1 di 3 Dell Venue 11 Pro USB Port Replacement: passo 5, immagine 2 di 3 Dell Venue 11 Pro USB Port Replacement: passo 5, immagine 3 di 3
    • To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
    • The two ribbon cables connect the keyboard attachment ports to the motherboard. Damage to either cables can induce problems with the Dell mobile keyboard.
  6. Dell Venue 11 Pro USB Port Replacement: passo 6, immagine 1 di 3 Dell Venue 11 Pro USB Port Replacement: passo 6, immagine 2 di 3 Dell Venue 11 Pro USB Port Replacement: passo 6, immagine 3 di 3
    • The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
    • Pulling the ribbon cable out before unlocking the connector can potentially damage the cable.
  7. Dell Venue 11 Pro USB Port Replacement: passo 7, immagine 1 di 1
    • There are adhesive strips between the device and the two ribbon cables we disconnected. Pull each cable away from the device just enough to break the adhesive bonds.
  8. Dell Venue 11 Pro USB Port Replacement: passo 8, immagine 1 di 3 Dell Venue 11 Pro USB Port Replacement: passo 8, immagine 2 di 3 Dell Venue 11 Pro USB Port Replacement: passo 8, immagine 3 di 3
    • Use your pin punch driver to push into the hole on the sim card, then pull out the sim tray.
  9. Dell Venue 11 Pro USB Port Replacement: passo 9, immagine 1 di 3 Dell Venue 11 Pro USB Port Replacement: passo 9, immagine 2 di 3 Dell Venue 11 Pro USB Port Replacement: passo 9, immagine 3 di 3
    • Insert your plastic opening tool between the screen and frame, and run the tool around the edges to separate the frame from the tablet.
  10. Dell Venue 11 Pro USB Port Replacement, USB Port: passo 10, immagine 1 di 1
    • Start by removing the top ZIF USB ribbon connector
    • If you are replacing the motherboard by itself, then skip steps 23, 24, and 25.
  11. Dell Venue 11 Pro USB Port Replacement: passo 11, immagine 1 di 3 Dell Venue 11 Pro USB Port Replacement: passo 11, immagine 2 di 3 Dell Venue 11 Pro USB Port Replacement: passo 11, immagine 3 di 3
    • To remove the ribbon cable, move the black retainer upwards. Then pull the ribbon cable rearwards to remove it.
  12. Dell Venue 11 Pro USB Port Replacement: passo 12, immagine 1 di 1
    • You must then remove the ribbon cable connected to the USB port located here.
  13. Dell Venue 11 Pro USB Port Replacement: passo 13, immagine 1 di 3 Dell Venue 11 Pro USB Port Replacement: passo 13, immagine 2 di 3 Dell Venue 11 Pro USB Port Replacement: passo 13, immagine 3 di 3
    • Using a Philips #000 screwdriver remove the two 2.5 mm screws indicated.
  14. Dell Venue 11 Pro USB Port Replacement: passo 14, immagine 1 di 3 Dell Venue 11 Pro USB Port Replacement: passo 14, immagine 2 di 3 Dell Venue 11 Pro USB Port Replacement: passo 14, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of tweezers disconnect the connector from the circuit board
  15. Dell Venue 11 Pro USB Port Replacement: passo 15, immagine 1 di 2 Dell Venue 11 Pro USB Port Replacement: passo 15, immagine 2 di 2
    • After disconnecting all the pieces, remove the USB port circuit board with your fingers
Conclusione
Altre 7 persone hanno completato questa guida.
Tom Nguyen
Membro da: 09/28/17
1.277 Reputazione
6 Guide realizzate
USF Tampa, Team S3-G1, Nance Fall 2017 Membro di USF Tampa, Team S3-G1, Nance Fall 2017
USFT-NANCE-F17S3G1
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,837
