Salta al contenuto principale
Dell Precision M3800 USB Port Replacement
Cosa ti serve
  1. Dell Precision M3800 USB Port Replacement, Back Cover: passo 1, immagine 1 di 2 Dell Precision M3800 USB Port Replacement, Back Cover: passo 1, immagine 2 di 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 USB Port Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 USB Port Replacement, Battery: passo 3, immagine 1 di 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 USB Port Replacement, USB Port: passo 4, immagine 1 di 3 Dell Precision M3800 USB Port Replacement, USB Port: passo 4, immagine 2 di 3 Dell Precision M3800 USB Port Replacement, USB Port: passo 4, immagine 3 di 3
    • Disconnect the orange wire with the two pull tabs by pulling upwards on the pull tabs.
  5. Dell Precision M3800 USB Port Replacement: passo 5, immagine 1 di 3 Dell Precision M3800 USB Port Replacement: passo 5, immagine 2 di 3 Dell Precision M3800 USB Port Replacement: passo 5, immagine 3 di 3
    • Remove the single 3.5 mm screw at the top of the left side holding the silver bracket using a Phillips #00 screwdriver.
    • Remove the LAN chip by pulling from the top away from the connector.
  6. Dell Precision M3800 USB Port Replacement: passo 6, immagine 1 di 3 Dell Precision M3800 USB Port Replacement: passo 6, immagine 2 di 3 Dell Precision M3800 USB Port Replacement: passo 6, immagine 3 di 3
    • Disconnect the wires that are connected to left side of the motherboard with a hooked prying tool.
  7. Dell Precision M3800 USB Port Replacement: passo 7, immagine 1 di 2 Dell Precision M3800 USB Port Replacement: passo 7, immagine 2 di 2
    • Disconnect the black wire that is connected to left side of the motherboard.
  8. Dell Precision M3800 USB Port Replacement: passo 8, immagine 1 di 3 Dell Precision M3800 USB Port Replacement: passo 8, immagine 2 di 3 Dell Precision M3800 USB Port Replacement: passo 8, immagine 3 di 3
    • Unscrew the three 3.5 mm screws that secure the circuit board using a Phillips #00 screwdriver.
    • Remove the circuit board by lifting upward.
    • To fully remove the USB ports from the circuit board, you'll need to desolder the points. Use the How to Solder and Desolder Connections guide for more information on soldering and desoldering connections.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 26
Tutti i Tempi: 668
