Salta al contenuto principale
Dell Latitude E6530 Fan Replacement Replacement
Guida Archiviata
Questa guida รจ mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Dell Latitude E6530 Fan Replacement Replacement, Fan Replacement: passo 1, immagine 1 di 1
    • Begin by flipping the computer over to the bottom.
    • Using a spudger, insert it into the corner of the back panel and move it around the panel.
    • Remove the back panel completely.
  2. Dell Latitude E6530 Fan Replacement Replacement: passo 2, immagine 1 di 2 Dell Latitude E6530 Fan Replacement Replacement: passo 2, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the seven 1 mm screws.
  3. Dell Latitude E6530 Fan Replacement Replacement: passo 3, immagine 1 di 1
    • Unhook the cord connecting the fan to the computer.
    • Carefully pull the fan out of the computer.
Conclusione
To reassemble your device, follow these instructions in reverse order. Refer to the troubleshooting guide and additional links if problem persists.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 25
Tutti i Tempi: 64
