Salta al contenuto principale
Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly)
Cosa ti serve
  1. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Bottom cover removal: passo 1, immagine 1 di 2 Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Bottom cover removal: passo 1, immagine 2 di 2
    • Loosen the 8 screws on the bottom cover. The screws will remain in the casing, they do not come out all the way.
    • Insert the pick or spudger between the upper and lower casing to release the plastic clips.
    • Attention needed: The clips are easily broken.
  2. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Disconnect the battery: passo 2, immagine 1 di 1
    • To disconnect the battery, pull gently upwards on the tab connector.
  3. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Bezel: passo 3, immagine 1 di 1
    • Using a pick or spudger, gently insert between the LCD back-cover and bezel to release the clips.
    • The bezel is also glued to the LCD panel.
    • Remove slowly to avoid tearing or damaging any components underneath.
  4. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Removing the LCD panel: passo 4, immagine 1 di 1
    • Remove the 4 Philips screws securing the panel.
  5. Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Connector: passo 5, immagine 1 di 3 Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Connector: passo 5, immagine 2 di 3 Dell Latitude E5470 LCD Panel Replacement (Display, not display assembly), Remove the LCD Connector: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the LCD paneland lay it flat on the keyboard.
    • You will be able to see the connector on the back of the LCD panel secured with some adhesive tape and a metal connector.
    • Udsing the tweezers, slowly lift the tape away to reveal the blue sticky protector. Removing the blue pad to see the metal connector underneath.
    • Using a spudger, lift the front of the connector up (highlighted by the white arrow).
    • Pull the cable back to release the cable from the connector.
    • To reassemble, follow the steps in reverse.
Conclusione
Altre 4 persone hanno completato questa guida.
Harvey
Membro da: 02/15/16
6.189 Reputazione
10 Guide realizzate
5Commenti sulla guida
Your presentation is perfect
sachida1986niit - Replica
Thanks very much :)
Harvey - Replica
Hello, will this model with touch screen work with non touch replacement LCD?
cellularcircuit - Replica
Damaged touch lcd and was not using touch , want to save some $ by installing not touch lcd..
cellularcircuit -
Thanks - seems that little piece of blue sticky protector was my whole problem, months of a flickering screen, that was temporarily fixed upon pressing on the bottom of the bezel. Upon opening up the screen, it was crooked. So I straightened it, put things back together, and the flickering seems to be gone. Cross my fingers!
Peter Lyons - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 45
Tutti i Tempi: 9,388
