Introduzione
If you have had your computer for 10-20 years or if your laptop has been having issues with blue crash screens, slower processing speeds, or not recognizing hardware. Then you need to replace your motherboard. Follow this guide will show how to replace the motherboard step by step.
Before beginning make sure you backup all important data files on the system onto an external memory device (A Hard Drive or USB)
Cosa ti serve
Perform a complete system backup and shutdown the computer.
Unplug the charger and remove the battery.
Remove the battery by sliding the lock tab and use your other hand to remove the battery.
Remove the 14 Phillips screws from the bottom of the laptop.
Two additional screws not circled need to be removed. One in the upper left (near the foot and circled screw), and one in lower center (at bottom right of RAM, end of STRIKE ZONE wording).
Remove three screws that hold the upper case to the motherboard.
Use a spudger to pry the three tabs by the CD-ROM to separate the upper and bottom casing.
Between steps 8 and 10, the display must be removed; you'll note in step 10's picture that the display isn't there.
1. Detach the ribbon cable that connects the display to the motherboard.
2. Move the display cable and WLAN cable so they don't get caught.
3. Unscrew the two screws in back
4. Lift the display's hinges out of the main assembly.
Altre 14 persone hanno completato questa guida.
2 Commenti
i used this to replace the thermal paste its really easy to follow simple steps
