Introduzione
This tutorial will guide you through replacing the SSD card of a Dell Latitude 7420.
Before starting, please ensure the device is turned off and disconnected from any adaptors or charging cables.
Likewise, use an anti-static band or mat when opening computers or handling components.
Cosa ti serve
Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
Use a Phillips #00 screwdriver to remove the two 2.0 mm screws holding down the SSD cover.
Remove the SSD cover.
Altre 3 persone hanno completato questa guida.
