Salta al contenuto principale
Dell Latitude 5580 RAM Replacement
Cosa ti serve
  1. Dell Latitude 5580 RAM Replacement, RAM: passo 1, immagine 1 di 3 Dell Latitude 5580 RAM Replacement, RAM: passo 1, immagine 2 di 3 Dell Latitude 5580 RAM Replacement, RAM: passo 1, immagine 3 di 3
    • Orient your laptop so you can access the bottom cover, with the fan vents facing upwards.
    • Use a Phillips #00 screwdriver to loosen the eight screws securing the bottom cover.
    • They are captive screws and do not fully come out of the holes. Don't force them or you may damage the screws or holes on the bottom case.
    • Insert the end of an iFixit opening tool or opening picks into the seam between the bottom and top case to release the clips holding them together.
    • Slide the opening tool or pick around the edge of the laptop until it is fully separated.
    • Remove the bottom cover.
  2. Dell Latitude 5580 RAM Replacement: passo 2, immagine 1 di 3 Dell Latitude 5580 RAM Replacement: passo 2, immagine 2 di 3 Dell Latitude 5580 RAM Replacement: passo 2, immagine 3 di 3
    • Push the clips on the side of the RAM out a few millimeters to release the RAM stick.
    • It will pop up at a 45 degree angle.
    • Hold the edges of the RAM stick and slide it out of the socket.
    • Be careful when replacing the new RAM that you line up the connector edge with the socket to avoid bending them. Once it is inserted, press down until it clicks and the arms securely hold the RAM stick.
Conclusione
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 22
Tutti i Tempi: 151
