Salta al contenuto principale
Dell Inspiron 531 Graphics Card Replacement
Cosa ti serve
  1. Dell Inspiron 531 Graphics Card Replacement, Side Panel: passo 1, immagine 1 di 2 Dell Inspiron 531 Graphics Card Replacement, Side Panel: passo 1, immagine 2 di 2
    • Place the desktop on its side. Make sure to place the computer on a soft but firm surface.
    • Locate and remove the two screws that secure the side panel to the desktop:
    • Two 1/4" Phillips/slotted combination screws.
  2. Dell Inspiron 531 Graphics Card Replacement: passo 2, immagine 1 di 1
    • Slide the side panel towards the back of the desktop in order to remove it.
  3. Dell Inspiron 531 Graphics Card Replacement, Locating the Graphics Card: passo 3, immagine 1 di 2 Dell Inspiron 531 Graphics Card Replacement, Locating the Graphics Card: passo 3, immagine 2 di 2
    • The graphics card is attached to the back of the desktop.
    • The graphics card is located below the three fans.
  4. Dell Inspiron 531 Graphics Card Replacement, Support Bracket: passo 4, immagine 1 di 1
    • Remove the screw that secures the support bracket:
    • One 1/4" Phillips screw
  5. Dell Inspiron 531 Graphics Card Replacement: passo 5, immagine 1 di 2 Dell Inspiron 531 Graphics Card Replacement: passo 5, immagine 2 di 2
    • Remove the support bracket by lifting up and out.
    • There are tabs that hold the bracket in place, therefor lifting up is an important detail.
  6. Dell Inspiron 531 Graphics Card Replacement, Removing the Graphics Card: passo 6, immagine 1 di 2 Dell Inspiron 531 Graphics Card Replacement, Removing the Graphics Card: passo 6, immagine 2 di 2
    • Locate the push tab that locks the graphics card into place.
    • Push the tab away from the graphics card and towards the fan.
    • Hold the tab in this position through step 7.
  7. Dell Inspiron 531 Graphics Card Replacement: passo 7, immagine 1 di 2 Dell Inspiron 531 Graphics Card Replacement: passo 7, immagine 2 di 2
    • Keep the tab pushed away from the graphics card (see Step 6).
    • Gently lift the graphics card up and out of the desktop.
Conclusione
Scott Havard
Membro da: 06/27/16
50.423 Reputazione
31 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,412
